Have a less security intrusive way of monitoring PI AF Audit trail is enabled
Currently the account used to monitor that the Audit trail is enabled requires sysadmin privileges. This is even checked in the related stored procedures. Our database security team sees this permanent need of sysadmin rights as a thread and also has doubts that this type of self-checking/correcting stored procedures is the best way forward. Can this not be done in a more secure way?
    Due to the limitation of SQL Server CDC, the account requires admin permission per Microsoft. As such, we are declining this request.
    AF relies on the change data capture feature of SQL Server for its audit trail implementation. The stored procedure that enables audit trail sys.sp_cdc_enable_db requires membership in the sysadmin fixed server role per MS link. The stored procedures handle it individually in order to ensure a user friendly error message is returned. Separate from SQL permissions is that audit users need to have admin permissions on the PISystem object. One reason is to prevent one user from gaining insight about how another user is using the system.
