Categories Data Archive
Confirm connection before writing to PI DA
No description provided
    In this particular example, my understanding is that the user uninstalled PI SDK 2014 and downgraded to PI SDK 2012. As a result, the what was running application that continuously writes data to PI Data Archive lost its connection and had to perform a re-connection. Unfortunately we have no control over user action that removes the underlying data access mechanism (in this case, uninstalling PI SDK) and we also do not know that this has occurred. We need to avoid "verify" a connection before trying to write the data as this is an additional overhead of a remote procedure call. Repeated RPC's for the sole purpose of verifying connection status negatively affects performance of the entire system. My recommendation is that the user who is removing the underlying data access mechanism should be aware that this may affect other applications and perform the necessary steps to avoid disrupting the data flow. As an example, user can first stop the application, perform the removal/installation of software, then restarting the application.
    Customer observed that while installing PI SDK, another application which was continously connected with PI Server, disconnected. So when application tried to write data through the PI Buffer, for the first time after the PI SDK installation, it failed. Customer propose an enhancement that verifies that the program is connected to the PI Server before trying to write the data. And if it is not connected, to allow the conecction, so it does not fail in the subsequent writing of data.
