Categories General
Introduce new features in PI-ProcessBook
1. Permanently set the custom output columns for ‘Tag Search’. For instance, I can add ‘Zero’ and ‘Span’ columns in the Tag Search window. However, when I close and reopen PI-ProcessBook, this setting reverts to the original configuration (Server, Tag & Descriptor). 2.Permanently set Trend Cursors. For instance, I can add one or more Trend cursors to a plot in Run mode. However, these disappear as soon as some modifications are done in Build mode or PI-ProcessBook is re-opened? Is there any solution or workaround? •         This will be of great help when there are some trends (with Trend cursors) being analyzed and additional tags need to be added to the same plot.  With the current scenario, tags can be added only in Build mode which will remove all Trend cursors on the existing Plot; the user will have to repeat the process (of adding trend cursors) again. 3.Set the third option ‘ProcessBook display (.pdi) File’ as default when ‘File->New’ is selected. At the moment, default option is set to the second option ‘ProcessBook entry’. 4.Display the ‘Descriptor’ at the right of the Trend together with Tagname & Units. At the moment, the descriptor is always displayed at the bottom of the Trend. The user has to switch his view back and forth to identify the descriptor for each trace that’s displayed on the Trend. 5.Set the ‘Trace Format’ for Pen 13 & upwards up to the max. count of 50. Currently, in ‘Define Trend’ dialog box, only 12 Pens can be customized. Trace #13 format will be same as Pen 1, Trace #14 same as Pen 2 and so on. The cycle repeats in Sets of 12  until it reaches a max. of 50 traces. 6. Incorporate a 'Step' switch feature for Analog plots so that the trace can be either seen in a 'stepped' fashion or as a continuous plot. At the moment, the 'Step' switch can only be enabled by Administrator.
    After 25 years, OSIsoft is retiring PI ProcessBook using a phased approach over several years. PI ProcessBook was the leading face of PI System for many years, paving the way for self-service visualization. Since then, technology and your expectations around mobility, scalability, and collaboration have evolved beyond what PI ProcessBook can deliver. OSIsoft has been actively developing and investing in PI Vision to provide you that next-generation, modern visualization experience. For additional information regarding the retirement of PI ProcessBook, please see https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000031882.
    As far as #3 goes, I agree it's annoying, but there is a workaround some people use in our office.  If you go to "View->Toolbars", then select the "Commands" tab, and then select "Supplemental Toolbar", the first button in the upper left (it looks like a little trend with a red trace) will create a new display when you click on it.  You can drag this button to whatever toolbar you want (typically we put it on the Standard Toolbar right next to the new document icon).
