Request that the install kit inform the user of pending installs and unintalls
Today a coworker requested that I install the web api and web crawler on an application server that already was running analysis and notifications. I ran the AF install kit, selected api and crawler because I just wanted to add those and the software performed the install but also uninstalled analysis and notifications without warning. It was probably a bad assumption on my part that it would only install what I asked it to and do nothing else.
Please pass this along to tech support and/or developers. Request that the install kit inform the user of pending installs and unintalls.
CMAG-Mills Services
Georgia-Pacific LLC
1919 South Broadway
Green Bay, WI 54307-9130
steve.savoie@gapac.com
920.438.2736 office
920.241.1703 GP cell
920.265.9030 Personal cell
ADMIN RESPONSE
The latest PI Server 2018 SP3 Patch 2 installation kit has been improved to alert users all the components to be installed and/or removed if user Modifies an existing installation.
Guest
Which version of the setup kit are you using? The PI Server 2018 setup kit has been improved to handle what you described.
In response to Stephen Kwan, "Which version of the setup kit are you u..."
I believe GP is using 2017 R2 as their standard version. I will share your update with them.
