Some organizations do not provide admin accounts with write permission to the root C:\ directory. The install kits of most PI products copy the setup.ini to C:\pisetup.ini, and then write the logs to C:\ before moving them to %pipc%\dat, both of which require write permission to C:\. The only workaround for now is to find someone with that permission to run the kit (typically an IT member).
