Created by jerome.boudon
Allow to automatically disbale an analysis based on an expression
As a PSE user, I would like to be able to configure an expression which allos to automatically set or reset the exclude property on an attribute
    There is currently no plan to implement this idea. Since this is a one time exercise for when the elements are instantiated from temple, our recommendation is to either manually disable/enable the analysis, use If-then-else based on an attribute to only execute the proper analysis or (least desirable) use different templates.
  • jerome.boudon
    We have a Turbine Telement template. Some attributes depends on the type of the turbine. Actually, We have to manually disable some analyses in the Templates instances depending on the turbine type. We would like to be able set that : Analyse calc_TurbineInjectorAvgPressure : disabled if TurbineType = "Pelton" We are just trying to automate what we are doing manually
