Users would appreciate a utility that converts PI Performance Equation tags to Asset Framework Analyses, or into AF Analysis syntax.
Many have have several hundred Performance Equation tags, and the inability to easily bring them into AF has may limit adoption of the Asset Framework and associated tools.
One possibility would be to point an AF analysis or attribute to an existing PE tag, and for it to query the tag's EXDESC, scan class, et cetera to complete configuration of an analysis. Ideally the PE tag could be deleted or managed by AF afterwards.
Context (location within the AF) would need to be specified by the user, and we would not natively important any attribute (rather than tag) references this way. But it could help serve as a bridge between tools for those currently invested in Performance Equations.
ADMIN RESPONSE
The PE to Analytics utility is no longer available, and it is not officially supported by OSIsoft. If you have questions, comments, or feedback, please let us know in the comments.
Guest
We just posted an open source PE to Analytics utility on PI Square. Perhaps this would work for you.
https://pisquare.osisoft.com/community/all-things-pi/pi-server/blog/2018/03/28/af-2018-with-asset-analytics-pe-to-analytics-migration-utility
