Make it easier to select a table in the table lookup configuration pane
A complex AF system may have dozens of AF tables, being fed by different groups, int the same AF database. Whenever someone needs to configure a new table lookup DR, he needs to go through a big list to find the desired table, specially if there is no table naming convention is place. In order to simply this, it would be much easier to find the tables group by categories. This feature should be optional (i.e, the user could arrange the list by table name or table category).
