Automatically update the ConfigString of attributes and attribute templates when renames occur
The ConfigString of attributes and attribute templates stores information such as references to PI Points, substitution parameters and formula parameters that refer to other attributes or attribute templates, and the source unit (abbreviation of the UOM of the referenced PI Point). Currently, the ConfigString will automatically update to reflect the renaming of a referenced PI Point, but not the renaming of attributes, attribute templates, or the source unit. Please consider automatically propagating all renames to the ConfigStrings that use them.
    The configstring of a PI Point data reference contains the server ID, server name, point ID and point name. This enables the software to have a way to uniquely identify the configuration when the point name is changed since the ID's are unique. When a "Create or Update Data Reference" is performed on a PI Point DR, all substitution parameters are instantiated and "locked in". Storing all this additional information in every attribute, which there can be millions, would be detrimental to storage and memory need. As such we currently have no plans to implement this idea.
      Reply
      I completely agree. It is not very common to modify the name of an attribute, but if you do, it is needed to check if there is any Formula, String Builder, Table Lookup or even any PI Point Data Reference event frame attribute that uses it in order to modify there the name...
      Reply
      The renaming of attributes is much more common in PI systems whose Asset Framework hierarchy is not finished or is constantly being changed. For example, "Avg Flow" might later become "Average Flow", and that, in turn, might be renamed to "5-Minute Average Flow" if we want to add a "10-Minute Average Flow". You might also want to rename attributes for consistency across the PI Asset Framework, and the inconsistencies might not be discovered until the Asset Framework hierarchy is closer to completion. For example, "Run Status" might be called any of "Running Status" or "Running" or "On/Off Status".
