Saving the "Analysis Service Statistics" should be saved in XML instead of TXT since this is the actual format of the file
It is possible to change the format after it is saved, but it should natively  be saved as an XML.
    Reply
    Hi, Is this because you want to use a XML reader or are you trying to import this information into some other application?
