Categories System Management
Revise tuning parameter descriptions
As a general suggestion, please look through all the tuning parameter descriptions and fix any mistakes or inconsistencies between descriptions. This includes the ones that the user cannot see by default. All: Almost every tuning parameter description contains a string of the format "Value units are in [unit].". I wouldn't say that my mass unit is in kg; I would say that my mass unit is kg or that my mass is in kg. Consider changing this string to "Value unit: [unit]". Tuning parameters of the enumeration or bitmask type use inconsistent formatting with each other for presenting and delimiting each number/bit and its meaning. Consider using a new line as the delimiter. Replace "boolean" with "Boolean". Consider treating Boolean types as enumeration types (i.e. 0 = , 1 = ). Make sure that units are shown consistently (e.g. not "sec" in some places and "seconds" in other places). If the description is a single sentence fragment, be consistent in whether a period terminates it or not. Replace "periodically (once a minute)" with "once a minute". Replace "PI-SDK" with "PI SDK" and "PI-API" with "PI API". When 0 is a special case, consider treating the "0" and ">0" cases like enumeration values. General: EnableAudit - consider splitting into multiple lines for readability MMQ_LowDiskSpaceMB - replace ")(" with ") (" and specify who "support" is Archive: Archive_AutoArchiveFileSize - replace "a automatic" with "an automatic", replace ", You" with ". You", replace the 2 spaces with 1 space, consider rewriting entirely due to strange wording Archive_DataCoercionPolicy - consider splitting into multiple lines for readability Archive_DisableArchivingOnIOError - wording suggests that the tuning parameter enables a disable or disables a disable Archive_DisableArchivingOnIOErrorRange - replace all cases of 2 spaces with 1 space Archive_FutureAutoArchiveFileRoot - missing a period after "same prefix" Archive_LogArchivePercentFull - delete " (in percentage)" Archive_LowDiskSpaceMB - move "if this limit is reached" to the start of the sentence to make it clear that it applies to both of the clauses joined by "and" and not just the first one, replace ".." with "." Archive_MaxPrivateBytesPercentOfTotal - delete "Sets the " Archive_MaxQueryExecutionSec - delete "Sets the ", replace "0 has" with "0 indicates" Archive_MaxWriteCachePercentArcCache - delete "Sets the " Archive_ShiftRatio - replace "inverse" with "reciprocal" MarkArchiveGaps - consider splitting into multiple lines for readability Backup: Backup_LowDiskSpaceMB - replace the 2 spaces with 1 space, specify who "support" is, is the unit Mb (megabits) or MB (megabytes)? Backup_MaxHistory - delete " for which to save history" (you don't save history for a backup; you save history in or as a backup) Backup_TraceLevel - replace the 2 spaces with 1 space, separate the command into its own line for readability, misplaced modifier starting at "while" (it reads as if the overriding can be done when the command is used to run the Subsystem) Backup_UseSystemProvider - delete "there are " BackupVerification_NumArch - replace "by setting … 0" with "(BackupVerification = 0)" (otherwise it reads as if the parameter is ignored if verification was disabled by setting BackupVerification = 0, but maybe it would not be ignored if the disabling was set some other way) Base: EnableHostnameForFQDN - replace 2 spaces with 1 space PointDb_RemoveEmptySource - replace "startup" with "startup,", replace ". So" with " so that" Replication_ClockDiffLimit - "secondary" describes which noun?, what is "syncfailure"? Net Manager: Keepalive - should be renamed to "KeepAlive" for consistency with other tuning parameters, replace 2 spaces with 1 space MaxAuthAttempts - delete "Configures the " Snapshot: Snapshot_AnnotationSizeLimit - is it in kilobits or kilobytes? Security: AutoTrustConfig - consider splitting into multiple lines for readability Server_AuthenticationPolicy - consider splitting into multiple lines for readability
