Status Evaluating
Categories System Management
PI System Management Tools (SMT) as a web application
I would like PI System Management Tools (SMT) functionality to be available through a web-based application. This would allow administrators to perform PI System administration and monitoring tasks from a browser without requiring a locally installed desktop tool.
    Nov 11, 2026
    We're currently evaluating the future direction of PI System Management Tools and want to make sure we understand what our users need:
    To help us evaluate this properly, we'd love to hear more from you:
    • Which SMT workflows do you use most frequently?
    • What are your biggest frustrations or pain points with the current SMT today?
    • Which parts of SMT feel the most cumbersome or time-consuming?
    • Are there are administration tasks that require multiple tools or manual workarounds?
    • If you could improve just one thing about SMT, what would have the biggest impact on your day-to-day work?
    • When determining if something in your PI environment needs attention, are there any health, usage, configuration, or monitoring insights that are difficult to obtain?
    Your input is really valuable at this stage. The more detail you can share, the better we can understand what would genuinely solve your problems. Feel free to reply here and thank you!
    Nov 19, 2026
    Having the ability to easily check and bring to light tags which may be compressed incorrectly (either through high or low write counts), assessing for similarity between tags of similar units of measure for data fidelity using AI type embedded features would be nice
    Nov 18, 2026
      • Checking tag configurations, Add/Updating tags, Identifying Stale and Bad Points, Viewing archived data, reviewing log messages, archive status, backup status, viewing active connections and troubleshooting connections through the Network Manager, viewing snapshot/archive stats, viewing PI AF sync'd state, viewing module database contents, viewing interface list
      • It crashes a lot; it loses connectivity and cannot restore it without restoring the application.
      • If I change my displays, it often gets lost. It seems locked to a position. To resolve the issue, I have to maximize it from the taskbar, then I can move it where I want.
      • Archive Editor is clunky and doesn't work if you need to update values on both members of the collective, you can only add the tag one at a time. Often, I have to restart the application if I'm switching between collective nodes.
      • It would be helpful to have an overall system dashboard to easily view important components and highlight issues.
      • I'd love some smart built-in analytics to present overall system health and identify issues.
      • Can the PI Archive Audit Trail be built into SMT and can it be improved to provide formatted reports of changes as a PDF?
    • Similar to some of the other comments, our site isn't looking for a web tool for the future of SMT, I'd just love to see some of the existing issues fixed and some improvements added. My experience with other web tools is that they usually make things harder to manage, less efficient, and it introduces new security/connectivity concerns if accessing the tool remotely.
    • Maybe outside the scope of this request, but the PI AF Audit trail is impossible to work with when there's a ton of items logged, especially with the implementation of the PIEMDVB batch interfaces. I'd love to be able to search for specific fields, time frames, and sources, or to just filter out the PIEMDVB events.
    Nov 17, 2026
      • Checking security, log messages, archive status, backup status, viewing active connections, viewing snapshot/archive stats, viewing update manager, checking tuning params, checking versions, viewing module database contents (Interface settings), viewing interface list
        • Stability (frequently locks up, loses connectivity), nested frames take up a great deal of space on screen/ looks bad on smaller screens
      • Checking permissions should be faster (similar to AF permissions in system explorer), better search tools within operational screens (e.g network, archive, update)
      • Interface startup params in module database could be easier to see (ideally exposed in the AFSDK as they used to be)
      • Would like SMT to better provide operational insight (identify bad actors, recommend optimization, etc)
      • Understanding client demand is very difficult today. This is vital when we have bad actors starving other requests but also useful for demand planning and anticipating need for the system
    Oct 6, 2026
    SMT as a web application should be bundled into the PI Data archive installation, and not a standalone application.
    Issues:
    • SMT is unstable.
      • Ex: when querying message logs for greater than 1 day.
      • Does not reconnect automatically when your workstation network disconnects. SMT will throw an exception and requires the user to restart the application. (ie: locking your laptop at the end of a workday and picking up where you left off the next day).
    • Lot of deprecated or not useful modules
      • Stale and bad points - this is useless for large PI systems
      • modules I've never used:
        • AF link/module database
          • Module database would be useful if we were able to use it to push changes to interfaces
        • Batch
        • Alarms
        • PI Services
        • PI Version
        • reason Tree
    • SMT is slow
      • loading interface list or point source list is slow.
    • If the PI server has all of its threads consumed, then you are unable to use SMT remotely. You must use SMT locally or revert to using cmd line utilities.
      • ex: querying Get-PIThreadInformation remotely will timeout if the PI server is overloaded.
    What I would like to see:
    • better performance
    • better stability
    • expose PI system management functionality as part of the AFSDK or its own management SDK.
    • collective awareness
      • SMT should be able to manage changes accross all collective members.
        • ie: collective creation, decommissioning, promotion of new primary etc.
      • Tuning parameters should be applied to an entire collective rather than per host.
    • collective manager is bundled into SMT
    • remote interface management
    • PI collective health bundled into SMT
      • Something a little better than snapshot/archive statistics.
      • Heavy hitters report
      • ability to disconnect rogue users
    • interface health status
      • Stale and bad points check for interfaces
    • bulk point creation - import a csv of points with their respective configuration and construct them.
    • build points from defined template - save a list point configuration templates, that can be reused.
    With all the moving parts that comprise PI SMT it seems a very broad challenge to take them to a web platform. Besides being such a critical application to manage the PI System I do not see necessary to have a web client when we can easily access the tool from any server dedicated for this purpose. I think the effort required is very high for the added value to the platform.
    In response to Jaime Olmo ("With all the moving parts…"), PI System Management Tools currently doesn't have to be used from a PI Data Archive server. You can run it on other computers too. However, you still need to install it on every computer that uses it (e.g. on all of the computers of the PI administrators), since it is a client-side tool. If PI System Management Tools were a web application, then you would only need to visit a web link and you would be able to access the PI System Management Tools web page hosted by the PI Data Archive computer. Only a single installation on the PI Data Archive computer would be needed. We can see a similar idea in action when we compare the PI Interface Configuration Utility (PI ICU) to the PI Connector administration pages. The former must be installed everywhere that it is used, whereas the latter is accessible from any computer, as long as the security settings allow the connection.
    Edit: I think that I misread Jaime Olmo's post the first time. Having a dedicated server for PI System Management Tools to avoid installing and updating it on each client computer introduces the hassle of having to log into the server just to use PI System Management Tools and of setting up such a server in the first place. It is overkill. As for the process of migrating PI System Management Tools to a web application, there is less to move over than you might think. A lot of the stuff that is available in PI System Management Tools is obsolete.
    To answer the administrator's questions:
      The idea of PI System Management Tools as a web application is so that we can eventually abandon the current PI System Management Tools. It doesn't matter how frequently we use each feature. If we ever need a feature, then it should be available.
      With that said, there are many features that I do not use, which are the deprecated ones. Below are the plug-ins that I hide in PI System Management Tools. I also don't use the menus at the top other than View → Settings… to hide the plug-ins listed below.
      • AF Link
      • Alarm Groups
      • AutoPointSync List
      • Batch Custom Names
      • Batch Database
      • Batch Generator
      • Interface List (soon)
      • Module Database (soon)
      • Performance Counters
      • Performance Equations
      • Ping
      • Reason Tree
      • SNMP
      • SQL Alarms
      • TCPResponse
      • Totalizers
      • The number of plug-ins, menu items, features, etc. that are not applicable to an up-to-date PI System. You need to know some of the history of PI to know which things you can safely ignore. For example, most of the database security tables can be given permission to only piadmin: A(r,w) to effectively lock them down and ignore them. PI Groups, PI Users, and PI Trusts are obsolete.
      • The fact that I can't specify that I don't want the PI Interface Configuration Utility or the PI Module Database Builder installed, and so I end up uninstalling them after the installation of PI System Management Tools.
      • The fact that it tracks PI Data Archive servers separately from PI System Explorer, and so I need to check 2 places if a PI Data Archive server migrates or gets renamed.
      • Having to memorize what does not synchronize between PI Collective members (e.g. Archive Editor edits, tuning parameters, PI Firewall).
      • You can read some of the other suggestions for PI System Management Tools, including the declined ones, for a better idea of how to improve PI System Management Tools. e.g. suggestions that mention the "PIPOINT" database security table.
      The "Identities, Users, & Groups" and "Mappings & Trusts" plug-ins can take a while to load when I am working remotely. Perhaps PI System Management Tools could do some bulk calls to reduce communication with the on-site servers.
      Yes! The entire PI Asset Framework is handled by another program: PI System Explorer. It wouldn't be a bad thing to have PI System Management Tools and PI System Explorer be combined into the same web application.
      Also, there is a lot that needs to be manually kept in sync between the PI Data Archives and the PI Asset Framework (e.g. security, Engineering Units versus Units Of Measure, digital state sets versus enumeration sets).
      Turn it into a web application!
      All of them? We currently need to use the PI Interface For Performance Monitor, but I don't use it because it is not critical in my case and because I want to move away from PI Interfaces. The PI Connector For PI System Health was decent except for the fact that it used up a lot of tags for the PI Data Archive message logs, but it is no longer available. PI System Health would have been good if it was easier to set up and actually had a generally available release.
    PI System Explorer web app suggestion: https://feedback.osisoft.com/forums/555148-pi-server/suggestions/31691545-pi-system-explorer-pse-pi-af-web
    I think that the PI Collective Manager should be integrated into the PI System Management Tools web application.
