If the Compressing attribute of a PI Point is set to Off, then the compression settings are greyed out, which makes sense because they are irrelevant if Compressing is Off. However, if a PI Point has its Archiving attribute set to Off, nothing is greyed out, even though the exception and compression settings and the Compressing attribute are all irrelevant. I propose changing the layout of the Classic tab to reflect the relationship between these settings. If Archiving is Off, do not show the user the exception settings, compression settings, or the Compressing attribute. If Archiving is On, show the exception settings and the Compressing attribute. Only show the compression settings if Compressing is On. For extra clarity, consider making an exception equivalent to the Compressing attribute.
I don't have any additional details to add. I just feel that the user shouldn't be able to set settings that don't matter due to some other setting. Disabling settings that don't matter helps the user focus on what does matter and helps the user understand when some settings matter and when they don't.
