Categories Notifications
Allow Notification Display of the target attribute using any UOM
We default Element Templates to SI Units as standard, which makes sense, but we have Sites that are Imperial and Sites that are metric. This extends to certain department (wells, for example) using different units of measure to the default. I need to be able to send notifications to some people in a unit of measure that is not the template default (i.e. imperial), but there is no ability to do this without making duplicate attributes with different default UOM's.
    Would you want to do this per notification (template) - i.e. everyone that gets a notification from this notification template would get that UOM? or per contact? Would you want to do this per UOM or per attribute - i.e. one attribute would be "ft" but another attribute would be "m"?
    In response to Stephen Kwan, "Would you want to do this per notificati..." I would want to do this per template, so I could have imperial and metric templates of the same attributes.  A better alternative would be to select the UOM when picking the attribute for the template. That way both values of each attribute could be on one template, making it suitable for all departments.
