Categories Event Frames (EF)
Option to write EF template attribute result back into a PI-tag
Creating a possibility to populate PI-tag's based on the Events. These PI-tag's can be used in reports/displays. Generating batch, daily, hourly, shift and other "event" driven values and store them in a specific PI-tags would very easy and may reduce the performance load of the system. Calculations are triggered only when the events happens. Possible solutions: 1) Adding a Analysis tab to the EF frame template for mapping/calculations 3) Extend the Output Expression to enable the use of EF (child)attributes 2) Extending the function EventFrame enable the use "EF (child)attributes names" instead of 'Starttime','EndTime,'Duration' only
    This may be similar to the request to use Reason Codes in attributes or PI Tags.
