Categories Event Frames (EF)
To have a ‘second’ Reason column available
It would be great to use Event Frames to classify and afterwards be able to do Equipment Downtime root cause analysis. We’re using Reason codes on the predefined field, however it would be great to have a second available Code Editors than “Reason Code Editor”, like “#machine Code Editor”, giving the chance to insert or select what was the main Equipment causing the stoppage. This means having the possibility of more than 1 dropdown list of selections available.
    Can you clarify which product you're referring to?
