The editor window for analytics is so small. If you create an analytic variable longer than 5 lines you have to start scrolling.
Guest
This is a key need identified recently for our AF developers - either to expand single lines to be an appropriate size to view all code, or else as a larger 'Advanced' editor view to edit all lines at once, or copy-paste to other windows for editing. The current code view is not sufficient/comparable to other modern code editors.
We often have multiple layers of if() and convert() statements, and these can be very difficult to visualise or troubleshoot using the default editor, and we are struggling to find other tools that would make this any easier.
Working in the cramped confines of the current AF Analysis editor is not sufficient for many of the engineering calculations we're building.
