I want to stop my Event Frame after an amount of time that is stored in an AF Attribute. For my use case, the amount of time from the beginning of an Event Fame is an end triggering condition. One way to do this, would be to allow the EventFrame("Duration") function to be used as an end trigger.
Aggree, we have several cases where beeing able to use EventFrame("Duration") as EndTrigger would make our lifes much easier :)
Can also see some advantage of beeing able to use EventFrame("startTime")
Event Frame Generation is made much more difficult if a specified time range cannot be selected, in industries that don't have SCADA systems or data is not constantly being sent by a device (LAB scale instruments), it makes it extremely hard to configure event frames, or your left configuring multiple additional analysis that could be rather easy with the setting. I would also consider this to extending it to also be able to use EventFrame("startTime") as well as duration and start time could be used in multiple ways to close and EF.
