Created by Gael
Permanent disable of non used AF Analysis
It would be interesting to be able to permanently disable an AF analysis if this one is not used within the template. This could be a scheduling option: Permanently Disable The status of the analysis would indicate that this analysis is permanently disable and this is "normal". There are many cases that this feature will be used to avoid creating multiple templates.
    Please help me understand why you wouldn't just remove this analysis if it's permanently disabled in the template?
    Hello Stephen, if you define an Analysis at the Template level but don't want to run it for an element based on that template, your only option is to Stop it, but it is still shown in the list. There is a risk that someone could start it thinking it was stopped by mistake. If you had the option to Disable the Analysis, it would be a clear indicator that the Analysis is not apply to the element.
    Currently in PI System Explorer, we use "Enable" and "Disable" already for an analysis. I think what you're describing is a different state that differentiates it from the currently available states. Am I understanding your request correctly?
