close/open event frames based on events, not transitions
I use analysis to toggle a boolean or integer from 0 to 1. This is used as source to close/open event frames (step continious mode). this is working fine in real-time. But when I do a recalculation for a part of time in the past (not until *) on the analysis toggling the boolean/integer, the result can be that the last event (on thePI point) in that time frame is equal to the next event. Causing wrong results when the recalculation of the event frame generation analysis is done. If we could tell to close/open an every event we would not run into that issue
    Hi, in reviewing this idea, I am not fully understanding your use case. Can you please provide an example?
