Include subseconds in output timestamp from variable
Currently we have an analysis with the output timestamp set to be a variable within the analysis. If I map that variable to an output, it includes the subseconds, but the output time for the analysis is truncated to the second. The output time for the analysis should also include the subseconds.
    Is there a work-around solution for this? The missing sub-seconds is very annoying when you want to pre-process a signal.
    Unfortunately there is not a workaround. We have identified this to be a bug. We do not have a forecast on when this bug maybe fixed at this time.
    Hi,   same problem with the Event Table symbol.     Regards, Tomas
