Allow dynamic PI Point data references for analysis outputs
Created on behalf of a customer: In order to use fewer attributes in an element, a customer hoped to output analysis results to an attribute with a dynamic PI Point data reference. Unfortunately, with the use of substitution parameters or with string builder, the "dynamic" PI Point data reference will only resolve the tagname once - upon creation (or when the data reference is manually updated). It doesn't act dynamically because it's not actually designed to act that way. The current workaround is to create all necessary output attributes, categorize them, and flatten/hide/minimize all categories containing the attributes that are not important at the time to reduce clutter.
    Reply
    I am the customer who requested this. Another workaround would be to have a function in AF or analytics to force a substitution parameter resolve.
    Reply
    The same has been also requested for any attributes used by an analysis that get their PI point name from a table. Currently, the attribute gets resolved only during analysis startup. Changes to the underlying table require the service restart.
    Reply
    hello everyone, someone can give me a demonstration of the workaround described by Ryan Biggins, please.
