While creating and/or debugging analyses in PI System Explorer, I would like to have available an instant evaluation dialog.
This would be something I can bring up empty, and start typing (if in template, use the context of the currently selected Example Element) to evaluate a formula.
If I right click a formula or expression already placed in a variable I would like to see "Evaluate in Instant Window" or "Evaluate instantly", where the dialog is brought up with that text pre-defined. If the expression you right clicked contains time expressions (such as start time, end time) I would like to see these pre-evaluated, if they refer to other expressions or are set with PI Time expressions. One if the things I spend most time doing while debugging is changing "T+6h" and "Y+6h" to their full "18-Feb-2019 06:00" equivalents.
Another thing I spend a lot of time doing is going between the Element -> Analyses tab to the Element Template -> Analysis Template counterpart, to change things. If I was able to debug things for a template-bound analysis using an instant window it would save time.
