Asset Analytics Evaluation Trace logging should write the Questionable/Substituted/Annotated flags present on input data to log file
As a troubleshooter, I use the Analysis Service Trace logging to determine why certain analyses are not returning the expected results. Currently, Analysis Service Evaluation Trace logging records the inputs and outputs for each analysis. It would be helpful if they also recorded the inputs' Questionable/Substituted/Annotated flags for PI Point Data References, since these flags can sometimes affect the value of the outputs.
