Substitution Parameters in Analysis Template Names
As an AF administrator, I want to configure analysis template names using Substitution Parameters to distinguish analysis from each other with PSE and in AF SDK Applications.
ADMIN RESPONSE
We do not have any plans to implemented this request.
Guest
Substitution parameters are typically used during an auto-creation process. For example, you would use substitution parameters when creating PI Point names when creating new elements and attributes from templates, or when creating event frames. Can you better explain what you're trying to do in the case of analyses? Are you referring to using substitution parameters when creating analyses from templates or some other use case?
