As a PI Administrator, I want to know which tags are being used at which PI Analysis so I can know exactly if there is already another Analysis writing to a tag and avoid duplicated or wrong data.
Guest
Oct 27, 2026
This is a common challenge in larger PI environments. Finding which analyses read from or write to a tag shouldn't require digging through AF manually.
We've been working on this with Osprey, including mapping dependencies between tags and analyses, identifying potential conflicts, and tracking changes over time.
The bigger issue we've seen is that these dependencies often go unnoticed until something breaks downstream.
Please implement a search function for this already. It really should have been a search that was a standard tool from the release of asset framework. Now im being told by support to develop our own tool with programming/script just to query where the analysis location is that is writing a tag that should be in the software already
Where? Are you just looking for something that alerts you when two analyses are writing to the same place, regardless of where it is in the database (or even server)? Is this a common scenario for the customer, or do they do this unintentionally during configuration? If it's unintentional, what is the common path to getting into that scenario?
You can get a higher level look at your analysis via PI Builder and pulling in attributes and analysis. This will give you all the PI points data reference string configurations associated with attributes. While this won't exactly map it together, you can look for duplicate config string (or tag references) across attributes.
It would be nice if there as an additional trait in a PI Tag that specifies if it's being written to in analysis and the analysis path. Currently there isn't a great way to find tags that are being written to via analysis unless you've done a good job classifying it with a unique point source and adding some notes in the extended descriptor.
I would like to see AF Analysis populate this new field or fields with information pertaining to if it's data is coming from analysis and the AF path for the analysis so we can easily find these in our AF system.
As we increase our use of PI Analytics, we are having difficulty keeping track of tags being written to by Analysis. For any tag, it's difficult to determine when the Analysis lives in AF, or if the tag is being written to by Analysis at all!
there are times I cannot easily find what analysis is writing to an attribute if the tag has more than one location in AF. this information would be extremely helpful!
I understand why it's useful to know which PI Point are analysis outputs. However, the suggestion to add a PI Point attribute may not be the best way to accomplish this. Thank you for your comments and votes. We'll continue to evaluate what we can do to help our users.
We add the AF path (to the output-attribute of the analytics) into the calculated tags extended description.
This is a manual process but saves a lot of time tracing tags back to the source. This can be done easily if AF creates the tags, however this set-up is always a manual process.
It would be great if analytics did this automatically, as an option. The extended descriptor or source tag attribute is not used by analytics, so in most cases should be available to use.
Can't you just put all these tags with their own point source?
