Created by Philipp Even
Created on Oct 30, 2024
if then else in Analysis still checking/executing both parts
If then else clauses are often used for input filtering for our analysis in AF. We often face the issue that analysis cause errors although the part which should not be executed according to the condition is causing errors.
Example:
"if BadVal('attribute') then '' else TagEU('attribute')" is giving still errros when the attribute is excluded.
    Nov 13, 2024
    It also doesn't matter what order you your check it, it still doesn't work. For example, the below both fail
    If '..\|NumberOfCommunications' < 2 Then "N/A" Else '..\COM2|State'
    If '..\|NumberOfCommunications' = 2 Then '..\COM2|State' Else "N/A"
