When deactivating an alarm, the notification rule is disabled.
There should be a way to set a notification rule to be enabled in a certain number of days. For example, if I disable the notification rule, I want to set it to be reenabled automatically in 30 days without having to manually enable the notification.
I have several cases where the alarm (notification rule) needs to be disable because there are externals works that affect de value of the instruments. In those cases, I want to disable the notification rule and programing it for enabling automatically after two months (60 days) for example.
After this time has expired, we receive the notification il the problem is always present. This solution save time and resources because you don’t need to make a follow up in a separate file/ system.
