AIM (PCS) should have option to select a custom Alias name
AVEVA Identity Manager app (PCS) should have option to select a custom DNS Alias name through the UI.
Guest
Feb 11, 2026
If this case is found, PI Vision URL become "invalid site". - Two redunduncy PI Vision servers with Network Load Balancer(NLB) - Each server certificate was generated by PCS PCS can generate server authentication with FQDN for each PI Vision server. However, Load Balance's FQDN cannot be added into server authentication. So, user access PI Vision through NLB, browser said "invalid site". Even though PCS supports RSSO in 2024R2, customer cannot create multiple PI Vision server for redundancy. Please add the option to add SAN for NLB to generate server certificate.
Custom alias must also be supported when used for an RSSO (Redundant Single Sign-On).
