Currently, the sort order of PI Point search results varies depending on how the Point Source search criterion is specified.
When Point Source is specified as an exact match
Search results are sorted by Point ID.
When Point Source is not specified or a wildcard is used
Search results are sorted by Tag Name.
Because the sorting behavior changes based on the search criteria, users may see the same set of PI Points presented in a different order depending on how the search is performed.
Provide a consistent sorting behavior for PI Point search results regardless of the search criteria used. For example, the search results should always be displayed in one of the following orders:
Always sort by Tag Name, or
Always sort by Point ID
A consistent sort order would improve usability and make search results more predictable for users. It would also simplify comparison of search results across different searches and reduce potential confusion caused by varying result ordering.
